stl output glitch
stl output glitch
stl output glitch
hi,
i have modeled the attached object and have exported to stl and it has a glitch in one of the holes.
im not sure how to fi this i have tried re exporting my original version that use to work perfect and now does the same thing. the mack front wheel is the one that use to work perfect but now suffered the same glitch.glitchglitch
Hi all,
i have found a solution after some intense googling.
turned FACETRES to 10
problem solved.
