still learning filleting and array
Hiya, am trying to get to the picture, can you help? Am wondering if asking too many questions on the forum...
Accepted solutions (3)
imadHabash
Hi and welcome to AutoCAD Forum,
Please feel free to ask any time . i open your CAD dwg :
  • Always make sure that you enter and use the right given values .
  • your needed array shapes are incorrect , you have to check your distance !!
  • Explode the other shape so you can Fillet with radius .
Imad Habash
vinodkl
Hi @elmira.robinson
You can ask any number of questions you want and people in the forum will help you out and that's why the forum is there for, to help everyone🙂
See the screencast on how you can fillet the object and create the polar array
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Thank you!
For some reason I can't trim the circles. What am I doing wrong?
imadHabash
i found NO problem , you may need to check ( PICKADD = 2 ) and ( PICKFIRST = 1) system variables .
BTW ... don't select dimension lines to trim with .
Imad Habash
vinodkl
Hi @Anonymous
I am able to trim the circle without any problem. Can you let know where exactly you are not able to trim🙂 You can attach a screenshot?
