I know the issue of importing STEP files has been discussed, but I am running into a problem that the STEP file , once imported, I cannot seem to use the object. I feel like there is something very simple I am over looking.
When I import the file. The object is blue. Not sure if that means something. (SEE PHOTO 1)
When i create an object/block in autocad, it is a different color (photo 2).
If I try and use union to combine, it does not work (photo 3) , saying "Two solids, or coplanar regions must be selected"
I have tried to "Convert to solid" but its says "object cannot be converted"
Do I need to convert this imported STEP object into something else to be able to work with it? I just want to add it to an already made autocad model.
thank you so much for your help.
@Anonymous,
john.vellek has edited your subject line for clarity: File size when converting PDF into DWG using Autocad 2018
