Good morning,
I am having an issue with one of my files where the .stb file is not plotting correctly. I know the .stb file works because I use it all the time. I have included screenshots below of a file that plots correctly with the settings and screenshots of the file that is not plotting correctly.
This first screenshot shows the plot settings for the file that is plotting correctly:
This screenshot shows that this file prints correctly:
This screenshot is of the plot settings for the file that is not plotting correctly. As you can see I am using the same .stb file in both the working file and not working file. I am also using the same layer settings in each file.
This screenshot shows that this file prints incorrectly:
Any suggestions or help would be greatly appreciated!
Thanks in advance!
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I am sorry that you are having problems with your plot style. Can you attach it and the drawing that does not plot properly in a ZIP to a post? I would like to see if it works on my side or what might be causing the issue.
Thanks John,
I found the issue and resolved it. It looks like someone converted the non working file to ctb at one point and the layers "plot" settings were changed from "Full Saturation" to a specific color.
We can consider the matter resolved! Thanks for the effort though - much appreciated!
