Standard TEXT SIZES
Standard TEXT SIZES
Standard TEXT SIZES
I waste massive amount of time trying to get the text right every time it is decided the print is to be done in a different size of sheet.
Please, help me out here. What are the possible standard text sizes for A0, A1, A2, A3 & A4 ?
imadHabash
you can control your text size as you wish and depending on your frame sheet and work flow and drawing scale. there is no fixed text size that you MUST use . the most important thing is to be found that text readable when plotted. so if you have the same drawing that you want to plot in different scale then you have make Annotative text style that absolutely will serve your issue. >> Click <<
Imad Habash
