- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Printing SSM linked hyperlinks is awesome. I've played with them enough to discover some tricks and hacks. What I can't figure out is why, when using a field with an associated hyperlink linked to the SSM, the PDF hyperlink "objects" are split up and applied to each individual character in the filed. The "SS-008" is one single SSM linked field, but when printed, each character has a separate but identical hyperlink field (Image 1) Any blue box can be deleted, and resized to leave one large pick box but that's worthless amount of post-processing. It also shows up in the PDF document properties as individual objects (Image 2) which I assume makes the file size larger than necessary (probably not by much.)
Has anyone dug in this deep to notice (and been annoyed by) this? Is there any solution? Is there any way to force the hyperlink to print the same size as the field box? I am using the OTB "AutoCAD PDF (General Documentation).pc3", Bluebeam Revu 2017, and 2018 Civil3d/Map3d.
Thanks.
