I'm trying to create a spot elevation block in 2D CAD. Ideally the block would contain a crosshair or point locating the spot and text which displays the elevation. I got halfway there by drawing a point then creating a text object with a field that reads the Z location of the point. You can modify the z coordinate by inputting the value in the properties menu... it will then update the text object. However, when i group the two elements as a block they lose their associated link so changing the z position in the properties menu no longer updates the text. Does anyone know how to fix this issue to accomplish what i'm trying to do or have any insight on a better what to achieve this?
Thanks!
