@leeminardi wrote:
@j.palmeL29YX Too bad AutoCAD's parametric features do not include splines for constraints or you could make the solution more automatic.
My above shown graphic method can in a little modified manner solve all that asked.
Assuming we have a given spline. (See >>video<<). To avoid that the further steps will change the spline I lock the geometry of the spline using a Fix constraint.
Now:
- draw a Line_1 and add Coincident constraints between their endpoints and the spline object.
- Add a Length d1 to this line. For demonstration I used for now a value of 25. In later steps we will see, the smaller this value of d1 the more precise will be the result. I can drag this line along the spline.
- draw a Line_2. Add a Coincident constraint midpoint to midpoint and a perpendicular constraint to Line_1. I'd suggest also to fix its length to any value (here I used 30). While dragging the lines along the spline the Line_2 will always stay perpendicular to the spline.
- draw a Line_3, add a horizontal constraint and a coincident constraint to the intersection between Line_2 and this Line_3 (as reference line for the following angular dimensions).
- Now we can add an angular dimension to show the angle of Line_2. But this is not what we need.
- As graphical representative of the spline's slope add a Line_4 parallel and coincident to Line_1 (red). You can now move the lines to any point along the spline and see the slope value.
- Assuming you need the slope at any given point you should add a coincident constraint between the Line_2 object and this point.
- If you move the lines to a point where the spline is not symmetrical in the range between the endpoints of Line_1 you can see, that Line_2 is not perpendicular to the spline (and Line_4 not tangential to the spline at this point). You can increase the accuracy of the result by decreasing the value of d1. In the video I got a precision of three digits with a d1 of 0.01.
What also can you do:
You search the point along the spline, where the slope has a given value.
- Because there may be several solutions you should first drag the lines near to the whished position. (e.g. in the shown example we find 5 points with a slope of 135°).
- Now we add a dimensional constraint (dcangular) with the whished value and the lines will snap to the right place. the intersection between Line_2 and the spline is the asked point. Be aware: the smaller d1 the more accurate will be the result.)
- If you want to drag the lines to another place, you first must either delete the dimensional constraint or convert it to a Reference Dimension (as done in the video).
This is only a rough description of the basic idea. Of course you can refine the workflow to meet your requirements closer.
HTH
Jürgen Palme
