specify hatch origin
jdfnnl
jdfnnl
I would like to offset the origin of roof hatches relative to those residing on a different plane so they do not appear seamless. It would be convenient to accomplish this from the properties panel, but when jogging the origin from 0,0 to say 0.5,0.5 this seems to have no effect even after REGEN. They only way I can get this to work is through HE command and in this way it is more difficult to specify a certain offset and this only works for individual hatches.
Here is the desired look so all the lines do not connect:
Kent1Cooper
For setting it for multiple Hatch objects at once, you can select them, and in the Ribbon, do the:
thing.  It doesn't let you specify a specific displacement from the current origin, but you could, in the example of your image and assuming the origin is along the main horizontal elements, pick on the midpoint of a vertical element to move the origin for a halfway offset.
Kent Cooper, AIA
jdfnnl
I am using Acad 2015 and prefer not using the ribbon. Any idea why changing the origin in the properties panel has no effect?
paullimapa
Have you tried using Hatchedit command dialog and selecting a new origin there?
Paul Li
IT Specialist
@The Office
dmfrazier
Since this particular hatching is for aesthetics, another approach might be to alter the two hatch scales slightly from each other. In the case of your screenshot, maybe change one to 0.45 and the other to 0.55.  Would that be easier and visually acceptable?
