Message 1 of 16
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
At least since AutoCAD version 2024, there has been an issue where the spacebar is often interpreted as a double-click. This naturally leads to command interruptions, etc. If you restart AutoCAD, it works normally for a while, but then the issue reappears. There is a trick to dock the command line at the bottom, which prevents this from happening, and it works. However, with three monitors, I need the command line in the center of the screen as a floating window. What else can be done to avoid this error?
Workstation: Ryzen 9 5950x@ 4,20GHz 64 GB RAM, Nvidia RTX 4090, Win10 Prof.
Rendernode: AMD Threadripper 2990wx@ 3,20 GHz 64 GB RAM, Win 10 Prof.
Autodesk Building Design Suite Premium 2025, VRay 7, ForestPack, RailClone, RichDirt, KStudio ProjectManager....
