Source objects are not displaying when moving or stretching
Message 1 of 15
I am selecting a group of objects to move or stretch. I select my first point and then am moving to my second point and the original objects are not displaying. The current position for the objects based on the second point are displaying based on the DRAGMODE setting but the original locations are completely gone.
They original location used to be displayed (dimmed) which enabled me to easily select a point within the selection set to move to.
I need to know what variable is controlling the display of the original location of the selected object.
Replies (14)
Message 2 of 15
qnologi
Under Selection Preview... Make sure both are selected... Smiley Wink
qnologi
Message 3 of 15
Both are selected and the objects are not displaying.
Message 5 of 15
These selections also do not change the situation. The selected objects are displayed as they are being moved but the original location is not there.
Message 6 of 15
qnologi
What about HIGHLIGHT, change it to <1>
qnologi
Message 7 of 15
qnologi
What is your DRAGMODE set to?
I set mine to Auto.
qnologi
Message 8 of 15
qnologi
Just wondering if you had any luck?
qnologi
Message 9 of 15
qnologi
Message 10 of 15
I have tried DRAGMODE at On, Off and Auto. All have the same affect in relation to the original location of the elements.
Message 11 of 15
Highlight is set to 1. Changing it does not affect the issue.
Message 12 of 15
Alfred.NESWADBA
Do you start command _MOVE or do you just select click-and-hold the left mouse button to move the object?
More interesting for me is if that happens when explicitly starting the command.
Also interested in: which AutoCAD version do you have and which service pack is installed, as well as which operating system are you on?
A more global check is to turn off the hardware acceleration (command _GRAPHICSCONFIG) and see if that happens again.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 13 of 15
It happens whether I run the move command first or select the items first.
Turning hardware acceleration off does not help.
It appears to be an issue with the color configuration. I set the uniform background to whit or black and I can see the original objects. They are a dark grey that was evidently too close to the background color that I had selected which made them appear invisible. I can't seem to isolate the setting for the color being applied to these original objects though. I would like to keep my background color, which is comfortable for my eyes and instead change the color of the ghost original objects.
Message 14 of 15
qnologi
http://help.autodesk.com/view/ACD/2016/ENU/?guid=GUID-CBB90ED0-9C2C-401A-B849-0EAD4E15DC7E
Set it to whatever color you like between 1 and 255. Smiley Wink
qnologi
Message 15 of 15
Vincent1967
that fixed it for me, thanks
