Create View missing
Create View missing
Create View missing
So, I just installed AutoCAD 2017 (with the student license), and i need the views from a solid, but I cant find the create view panel, I tried with the comand CUILOAD but there's no modeldoc.cuix (I read that if i load it the panel i nead should appear)
john.vellek
Hi @Anonymous,
Welcome to the Autodesk Community!
If you open your Ribbon menu to the Home tab, rt-click anwhere in the ribbon and select Show Panels. From there you should be able to select Views.
If you are trying to use Viewbase to see the views of your model you can also simply type Viewbase at the command line.
Let me know if this helps.
John Vellek
I tried with right clic and it didn't work, and when I type viewbase appear
this text line "Unknown command "VIEWBASE". Press F1 for help
john.vellek
Hi @Anonymous,
Please type ABOUT at the command line and paste in the result so I can determine the exact version of AutoCAD you are running.
For the error about "unknown Command" check out this AKN Article.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
