Hi Everyone,
Can anyone tell if there is a option to properly sort sheets in sheet set manager?
Solved by pendean. Go to Solution.
@pendean wrote:
"proper" as in numerical order?
Any reason you cannot just move them around? Or relabel them?
indeed, numerical order. I would expect numerical order by default adding sheets. didn't realize I can manually shift them 🙂 Thanks
pity there is no automatic sorting option.
Don't want to start another topic about Sheet sets...
Autodesk what is happening here? I can't do change to one file, but if I select all of them then I get this dialog, where I have to answer for all selected files....
Guys who is responsible for logic at your side??
