Some hatch appear to be outside of boundary
Message 1 of 15
I am having an issue with some hatch styles. Some hatch styles unless I zoom in very close to the object, appear to be outside of the boundary, the more I zoom out, the worst it gets. Any idea why that happens. See pic attached.
Replies (14)
Message 2 of 15
Patchy
List the corner of the hatch area, how far is it from 0,0 ?
Message 3 of 15
S.Faris
  1. Turn off Hardware Acceleration and restart Autocad (if this fails try 2nd option)
  2. Type HPMAXLINES Set the value to 1000000 (if this fails try 3rd option)
  3. Command: VIEWRES
    Do you want fast zooms? [Yes/No] <Y>: n
    Enter circle zoom percent (1-20000) <1000>: 20000
If that didn't get it done try these :
  1. https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Hatch-...
  2. https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Hatch-...
SALMANUL FARIS
Message 4 of 15
here is a pic with the info. I dont think distance from 0,0 is affecting it
Message 5 of 15
Nothing worked. I just installed the autocad 2019 a couple of days ago so it might be the new version that has problems..
Message 6 of 15
S.Faris
I am also using 2019, so it’s not that for sure. Let’s try this.
if the hatches are associative, make it non-associative, now select it and see if the boundary hidden lines match with your hatched element.
next, try exploding your hatch, and see if the everything is in 0 Z-value and within the boundary element
lastly, please upload a file in which you have a hatched element and also a exploded hatch element
Together all of us can figure this out. Don’t loose your hope 👍
SALMANUL FARIS
Message 7 of 15
I just noticed that if the hatch the is exploded it stops appearing to be going outside the boundary. Find attached cad document as requests. Thank you
Message 8 of 15
jayhar
1. Display Regen problems, repair corrupt AutoCAD files click here
2. Recreate Hatches
3. install the latest available updates for the graphics card click here
4. Command EXPORTTOAUTOCAD Click here
You just try this CAD file, i save as to AutoCAD 2013 format. no error seen in my system.
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | AutoCAD randomly crashes or freezes
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Message 9 of 15
S.Faris
Hi Sebastian,
  That confirms that the issue is not with the HATCH Element. But still let's give one more shot Change the HPORIGINMODE value to 5. Restart the Autocad.
I know that you answered this already, but since it is confirmed that it is only a graphical display glitch. HARDWARE ACCELERATION should be the culprit here.
  • 3DCONFIG -> HARDWARE ACCELERATION -> OFF
  • SMOOTH LINE DISPLAY -> ON
  • Restart Computer
SALMANUL FARIS
Message 10 of 15
Alfred.NESWADBA
Have you also installed the available updates? When you start command _ABOUT, does the exact version information show "2019.1.2" or only "2019". That should be verified first.
I also want to ask if this hatch pattern is a standard AutoCAD one or if it's a user defined hatch pattern.
When you change the hatch pattern to a different type like ANSI37 ... does it show the same effects?
In case you have activated the variable: HPLINETYPE please turn it to OFF.
In your dwg-file there are references, JPG as well as PDF, remove them and see if hatch is working better then.
At least one try: use copy & paste to copy the hatch borders (only the borders, not the hatches themselves) to a new drawing (new means based on an original AutoCAD template). And there start hatching again.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 11 of 15
Turning off the hardware accelerator, turning on the smooth line display and restarting autoCad worked!
Thank you very much. My drawings finally look good.
Message 12 of 15
S.Faris
If you don't mind "Accept that as a Solution" Since in future it will help others, who are facing the same issue.
SALMANUL FARIS
Message 13 of 15
jmayo5EJM2
Issue still exists in 2024. None of the recommendations above work on three entirely different PC's with different graphics cards. Two of which are certified hardware for Acad. This is an issue with the acad default gravel hatch pattern on certain complex boundaries. The hatch works fine in a simple rectangle or circle. No other hatch pattern in my collection produce the issue and a number of free gravel hatches available to download do not produce the issue.
Message 14 of 15
jmayo5EJM2
Message 15 of 15
igi_pop
Hatches, as many other acad things, have quirks. A complex border with many vertices will cause it do appear a bit funky. Also, if it picks up a crossing object, it can spill. If the hatch origin is far away - it will spill.
And that particular hatch, it's always been the worst to manage. Select the hatch, update origin to within border. It might fix it.
Also, notice that the spill, from what i can see by screenshot alone, roughly corresponds to the arc, as if it found the whole circle.
THere's alternatives to THAT hatch, most CAD ones work well, but that one...i bypass it whenever i can.
Cheers,
Iggy
Custom build;ASUS Z790 Prime Z790-P;i5-12600KF @3.6GHz; ASUS RTX3070Ti 8GB GDDR6X; Win11pro x64; 128GB RAM DDR4; SSD 2TB 980 PRO M.2, PCIe 4.0 x4,
"I'd rather have a bottle in front of me, than a frontal lobotomy."
AutoCAD Civil 3D Certified ProfessionalAutoCAD Civil 3D Certified Professional
