some entities would not show up in a viewport
I have a drawing, all entities show up right in the model space.
I use layers to control entities show or blank in different viewports.
But some entities just would not show up in one particular viewport,
even though I made sure the entity's layer is on for that viewport.
What could be wrong? What else should I check other than  layers?
Thanks!!
Dezhi
RobDraw
There could be many causes. Please provide more detailed information or, better yet, share the file.
Rob
imadHabash
pick inside this VP then type Layer command and check those layers status from VP Freeze tab .
Imad Habash
pendean
Community Legend
Community Legend
While inside a viewport, unlock it, set the viewport scale to 1:1, then Zoom>Previous and see if they reappear.
After you confirm all layers are thawed in the VP columns of LAYER command while you are inside that viewport.
