Solid Editing - Clean, not working
I have a 3d solid made from multiple 3d solids with Union. Although all the faces are parallel there are extra lines on the faces which I would like to remove.
I would like to use solidedit and clean which should remove the lines. But when I do it, it just asks to select a body again and nothing happens. How can I remove the extra lines.
SolidEdit command help doc says that it can only remove shared edges with on the surface.
But When I see your modeling, I cannot find shared edges with on the surface.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
JDMather
Is this what you need (see attached).
That's exactly what I am after. How did you do it?
Michiel.Valcke
_SOLIDEDIT -> 'Face' -> 'Delete'
