Snap to grid not working - Cursor/Pickbox not snapping
milanvidovic
Message 1 of 14
milanvidovic
Installed AutoCAD 2019. Snap is ON. Snap to grid is ON. And NO snapping. I know this question's been asked a million times. But it's incredibly frustrating and I don't know why it doesn't want to cooperate.
The snap dimensions/increments are matching the grid measurements. Why does it refuse to work?
Replies (13)
Message 2 of 14
ChicagoLooper
snapmode=1 & snaptype=0.
Chicagolooper
Message 3 of 14
milanvidovic
What's that? A command for the command line?
I put in both, still Snapmode does not work.
Also. How do i find/determine what my actual work space is? I figured I was too zoomed out or in to see what was going on. I really don't know what "5.0000" and "5.0000" means for my grid spacing. I assume it's whatever units I decided to use.
Message 4 of 14
milanvidovic
I really hate to double post, but I have to point out that I have turned legacy snap option to ON. It STILL does not work. This is just ridiculous.
Message 5 of 14
GrantsPirate
Maybe you are zoomed too far out to see that it is working.  Draw a line of any length at 0 degrees, then click on it and open properties.  Do the endpoints show numbers that are exact multiples of 5?  If so then snap is working.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 6 of 14
ChicagoLooper
To turn on your grid and your snap-to-grid make the icon shown below blue.
Left icon is  DRAWING GRID. Right is SNAPMODE.Left icon is DRAWING GRID. Right is SNAPMODE.
To determine your Grid Spacing, right-click on either Drawing Grid or Snapmode  and select Snap Settings. on Snap and Grid Grid tab you'll see 'snap x' and 'snap y' spacing. The numbers are your drawings units. Drawing units can be inches, feet, mm's, meters, and much, much more (see below).
Snap x and  Snap y found in Drafting Settings dialog box, Sanp and Grid tab.Snap x and Snap y found in Drafting Settings dialog box, Sanp and Grid tab.
Chicagolooper
Message 7 of 14
gotphish001
With computers today there is no reason to set limits to drawing space as people did years ago. Just leave it unlimited. It is also wise to try and draw things near 0,0 as drawing them way out in space for no reason just makes autocad do more work and can sometimes cause rounding issues. By way out in space, I'm talking 100's of thousands of feet or millions of feet.
Nick DiPietro
Cad Manager/Monkey
Message 8 of 14
ChicagoLooper
I agree, there doesn't need to be limits. However, there are times when large x and y values are necessary. For example, if you are drawing in a state plane coordinate system, then yes, the numbers are inherently large. Six and seven digits to the left of the decimal. Many Cad objects, such as points (monitoring wells, soil borings, fire hydrants, cell towers, etc.),  or polygonal objects (electrical transformers, lakes, parcels, building footprints, etc.) are drawn in state plane then cut and pasted (using 0,0 as copy basepoint and 0,0 as paste point) to other Cad verticals. For many, being far away from the origin doesn't matter. Afterall, is just a number, not a heavily weighted xref or something requiring a sophisticated Cad operation. I like to 'trust' Cad and let it do the heavy work. I like doing the easy stuff, like clicking the mouse.
Chicagolooper
Message 9 of 14
milanvidovic
I really wish it were that easy. Yes, both Grid and Snap are highlighted Blue and enabled. I've already familiarized myself with the key shortcuts as well.
I've zoomed WAY in, and WAY out to see if there's a difference. It just won't work.
Message 10 of 14
milanvidovic
ugh... Ok. I've figured it out. There was a problem with a template file i've been using. Strange. It's a really old one. Possibly from an AutoCAD 2013 release. I think even older. My drawing was Metric and I believe I chose the Imperial version of the template file I was working with. I started fresh and everything is fine. I'm completely new to the software, so i'm ASSUMING this is what it was. I realized late that I had been given two .dwt's. It's for an assignment. Is that something that actually could be conflicting? Template files? I don't know, apparently so. All is well now. Smiley Happy
Also... I've been trying to juggle around with trying different settings for Grid and Snap. Finding a right balance between the two so i can actually see the snap while NOT being zoomed in extremely close.
Message 11 of 14
anthony_gardner9GQQP
New Member
New Member
I have turned the Grid on and checked that all the snap spacing and grid spacing is identicle but it still does not snap to the grid
Message 12 of 14
cadffm
hi
grid is grid and snap is snap, is SNAP on?
Sorry for that question, but i am missing this point.
Tried with LINE command?
osnaps off? [F3]
Sebastian
Message 13 of 14
Kent1Cooper
If it snaps to grid locations when you are in a command, but not outside of any command, you can get it to snap even when not in a command with the SNAPGRIDLEGACY System Variable.
Kent Cooper, AIA
Message 14 of 14
pendean
Community Legend
Community Legend
Is this a problem in ALL of your files, or just this one that you could confirm can be fixable with a quick copy/paste into an empty blank DWG file then trying again?
And how far is your content from 0,0,0?
