I have a 3d solid model comprised of several different 3d parts. There are times when I need to check distances while I have a Live Section through.
Is there a setting that will ignore the section plane when snapping to points? I know I can generate a section block and check it that way, but was hoping there might be a way around?
John
You can select the section, and in it's properties change the property "Live section" to no temporarely until you measure your distance, and change it back afterwards..
Hi jhw3,
Did @elshawadfy great suggestion help to resolve your question? If so, please mark that post as an Accepted Solution. If not, please update your post so that I can assist you.
