snap spacing of dimensions
hilkek
hilkek
Can anyone give me information on the snap tracking of dimension spacing.
start dimensioning and when you go over a dimension you get two tracking points one on each side of the existing dimension so you can place your new dimension a specified distance apart. what turns this on and off and what controls the spacing.
j.palmeL29YX
Dimstyle (DDIM) -> Baseline spacing.
(is used by dimbaseline command and also dimspace command).
 Or you use Object snap Tracking (F11).
cadder
Jürgen Palme
hilkek
Thanks, I got that now what turns it on and off and is there anyplace in the help files that describes this, not using the dimspace or dimbaseline cmds
scot-65
Try reviewing DIMDLI and DIMCONTINUEMODE.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
cadffm
You can find the answer yourself easily.
Start searching for your keyword (for example dimspace),
then you will see 3 other help pages where this can find too.
If you are using the right keywords (dimension & space) you will find them.
Sebastian
j.palmeL29YX
And what did you find out? It would be nice for others if you share your knowledge.
cadder
Jürgen Palme
j.palmeL29YX
@hilkek  schrieb:
start dimensioning and when you go over a dimension you get two tracking points one on each side of the existing dimension ...
Do you work with the plain (Vanilla) AutoCAD or do you use a vertical product (e.g. Autodesk Mechanical or similar)?
cadder
Jürgen Palme
