Snap objects not showing up on screen
ayorkeALF6U
Observer Observer
ayorkeALF6U
Observer
Observer
I have a client that received a new computer (windows 11) with all specs meeting the system requirements for Autrocad 2023.  The problem is the snap object does not appear on the screen after applying it.
Troubleshooting steps that were taken:
Autocad and patches have been updated to 2023
there was an issue with the video card but that has been rectified.  Video card is a certified card.
Looking forward to your response
Thanks in advance,
Adam
pendean
Community Legend
Community Legend
@ayorkeALF6U wrote:
...The problem is the snap object does not appear on the screen after applying it....
Not sure what that means: can they provide more details, enough to follow along, PLUS screenshots or a video?
OR...
1) Do they need to just Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD2023?
2) Also consider turning off LINESMOOTHING and LINEFADING variables.
3) If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
4) If all else fails, then turn off Hardware Acceleration as a last resort, and start a support ticket through their subscription portal as explained here
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
ChicagoLooper
Hello @ayorkeALF6U
Please explain Snap Object. What is it?
Also, if the object(s) is on a locked layer, then the blue grips won't appear. Unlock the layer.
Chicagolooper
Kent1Cooper
If  by "snap objects" you mean the little green icons of different shapes for the different Osnap modes, and if  by "applying it" you mean calling for a particular mode, such as by typing one in [e.g. END] or bringing up the list with Shift+right-click or Ctrl+right-click and picking one, then:
Make sure you have the Marker item checked in the Drafting tab of the OPTIONS dialog box:
and I also prefer to have the aperture box showing, but that's optional.
Kent Cooper, AIA
