Smoothly transition between lines on different planes
Message 1 of 11
I have a simple case of having two lines, L1 and L2, drawn perpendicular to each other with one line on a high plane and one on a lower plane. The two work planes are parallel, they just differ in elevation.
I need to transition between these lines using a curve of a set radius which does not 'kink' at any of the tangents in all directions.
3D image below:
When I adjust the UCS so I can draw the arc between them, it is fine in plan but kinks in one of the elevations. How do I achieve a smooth transition?
For a wider context, this is for cable pulling, so the path of the cable cannot kink.
Replies (10)
Message 2 of 11
Kent1Cooper
I don't think that's geometrically possible with one  Arc.  It can be done with two, meeting mid-way:
I did it this way:  FILLET in plan with the Lines in the same plane;  place a POINT at the midpoint of the ARC;  MOVE the higher LINE up to its different elevation, and the POINT up half that distance;  UCS picking the two ends of a LINE and for the 3rd prompt, the POINT;  draw an ARC starting at the near end of the LINE, Ending at the POINT, and with the Direction option and Ortho on to make it come tangentially off the LINE;  same UCS and ARC with the other LINE.
Kent Cooper, AIA
Message 3 of 11
Patchy
Can it be 3darc?
Message 4 of 11
Kent1Cooper
@Patchy wrote:
Can it be 3darc?
I think the images in Message 1 are from the same kind of arrangement.  Yours has the same non-tangential  connections between the Arc and the two Lines that they don't want:
I'm attaching the drawing I made my images from.  While the two Arcs are tangential to the Lines, they are not quite exactly tangential to each other, but a lot closer to it than that.
Kent Cooper, AIA
Message 5 of 11
Would you be able to post a screen shot looking in the X-Z plane?
How do I access a 3D arc? When I type that, it's not recognising the command.
Message 6 of 11
Kent1Cooper
@Anonymous wrote:
.... How do I access a 3D arc? When I type that, it's not recognising the command.
It's just an Arc in a UCS set up [or the result of some 3DRotating and maybe Scaling] to get the ends to meet the Line ends.  I suspect it's the same as [or very similar to] yours in Message 1.
Kent Cooper, AIA
Message 7 of 11
Patchy
Open the attached drawing and do a 3dorbit in model space to see what it looks like in 3d.
Here is the link for that command:
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5757
Message 8 of 11
That arc is kinking in the Z-X plane.
I used the rotate UCS to make the arc in my original post, but I don't think it's possible to create what I'm after by just rotating the UCS.
Message 9 of 11
Kent1Cooper
@Anonymous wrote:
.... I don't think it's possible to create what I'm after by just rotating the UCS.
No, and I've decided I don't just think  any more [as in my first Reply], but am certain, that it's not possible with a single Arc under any circumstances.  Does a double-Arc solution, similar to my 2ArcTransition drawing [attached to Message 4] work for you?
Kent Cooper, AIA
Message 10 of 11
[removed]
Message 11 of 11
GrantsPirate
I would use the BLEND command.  You can use the control vertices, grips, etc.  to adjust it afterwards.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
