smoothening edges in a 3D model
j.bongers
j.bongers
A want to remove this cut out and change the height at the end of this curve to 0, in order to smoothen my model.
I tried to sweep it, but nothing works.
The angle of the 2 faces stand in a 90 degrees angle opposite to eachother.
What is the best way to do this ?
J.Bongers
imadHabash
Honestly i didn't catch your point enough .. But you can use PRESSPULL command that may help .
Imad Habash
j.bongers
Presspull only stretches up the solid that is not what I was looking for.
I now try to fit in a solid which I create with Sweep > Scale, but that is a way to work around it I guess.
Also I am limited because I cannot sweep a region which extends over te center point of the sweep path.
j.bongers
When I substract solids from it I get  the following
But the height loss is only 30% of the original height at the beginning.
There must be a better way to do this....
Jos.
j.bongers
Loft gives better results.
I had to figure out it myself this is the result
