I have problems drawing and adjusting lines due to small icons appearing with each drawn line. I don't know how to turn them off. It looks like they connect the lines to each other so it's not possible to move a line without moving the connecting lines.
Solved by nestly2. Go to Solution.
Solved by skintsubby. Go to Solution.
Hi klaas..
Welcome to the forum.
They are constraint markers. To turn off creating them set CONSTRAINTINFER to 0
To show / hide them check out CONSTRAINTBAR... or under the PARAMETRIC RIBBON as shown below.
Mark
Welcome to the Autodesk Forums
Those icons represent applied to your Geometry. If you didn't want them, it's probably a result of inadvertently turning ON the Infer Constraints button on the statusbar. To delete existing Constraints, use the Delete Constraints button on the Ribbon > Parametric tab or use DELCONSTRAINT from the Command Line.
It looks a little different over here because I am working on mac, but thank you for the information, it was very helpful
