AutoCAD Forum
slow mouse
4 REPLIES 4
r0879376
884 Views, 4 Replies
slow mouse
r0879376
when i'm in AutoCad and moving my crosshair it sort off lags, it is not as smooth as the 2021 version. i the new version its moves with a much slower respons. it's difficult to explane
my mouse is new so that can't be te problem.
sorry for the bad language, im from belguim.
slow mouse
Tags (1)
Labels (1)
4 REPLIES 4
RSomppi
in reply to: r0879376
RSomppi
Use a screencast to demonstrate.
Try a different mouse. Even new ones can have problems.
I would also look at your mouse settings.
pendean
pendean
Community Legend
Community Legend
If the other tips do not help...
Have you installed the 2022.1 Update yet? If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD/LT2022: reverting to DirectX11 fixes similar problems for most users.
Also consider turning off LINESMOOTHING and LINEFADING variables: if still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, then turn off Hardware Acceleration as a last resort.
Valentin-WSP
Valentin-WSP
@r0879376 ,
Consider the suggestions from this link:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
@r0879376 ,
Emilio Valentin
r0879376
in reply to: pendean
r0879376
the GFXDX12 to 0 worked
AutoCAD Inside the Factory
