sketchup model to autocad not a solid
I've created a drawing in Sketchup, and according to Sketchup it is a solid.
I have exported it in to DWG format. When I open it in Autocad, it tells me it is not a solid.
What am I doing wrong? I am new to Autocad and trying to teach myself.
Using Autocad 2019
Attached both files
Thank you!
beyoungjr
Only dwg file is attached.
I opened your dwg file and find that the object imported to AutoCAD as a Block.  Usually IGES files from vendors import as Blocks.
I Explode the Block, as I do with vendor models.  I find that you have thousands of objects, including over 6900 Polyface Mesh objects.  These Mesh objects are surfaces and not solids so I question the export from Sketchup.
I isolated all of the mesh objects on their own layer and turned all other objects off.
I attempted to convert all mesh objects to a solid but the process fails.
The mesh looks OK but obviously some issues.  I'll play a little more.
Blaine
Blaine Young
Senior Engineering Technician, US Army
j.palmeL29YX
Maybe the attached file will help you.
(I exported to Inventor, stitched to solid and reimportetd into AutoCAD).
cadder
Jürgen Palme
I tried attaching the skp. file but it wouldn't let me. I tried again and no success.
j.palmeL29YX
@Anonymous  schrieb:
I tried attaching the skp. file ... no success.
Maybe this file type is not allowed here. Pack it into a zip and upload this.
cadder
Jürgen Palme
Here is the zip file
