If I dubbed a sketch block with an ERP no. For instance 12345678
Would it be possible to somehow indicate that in the BOM on the drawing?
Lets say I have added 2 of the same sketch blocks to my drawing. What I would like for the BOM to then say is:
Qty, Item Number
2 12345678
Like Inventor can do with its parts.
Solved by john.vellek. Go to Solution.
Solved by TheCADnoob. Go to Solution.
Im not sure there is an easy way to achieve this out of the box.
BCOUNT will give you a number if you want to populate manually
DATAEXTRACTION can also give you a count
You look into third party scipts and lisps as well like this one http://www.cadig.com/products/autocad-field.php
CADnoob
So you can't make AutoCAD's BOM count objects automatically like Inventor?
Hi @Anonymous,
Core AutoCAD does not include a BOM feature. However, if you are using blocks with attributes you can create a table using data extraction that does basically the same thing.
I made a quick video to show this process.
HI @Anonymous,
I am checking back to see if my post helped you with your problem or question. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
