Single Line Text Problem
When i insert the single line text its just told me to set the point and then the rotation,(usually it set the size just before the rotation) but i cant set the size, so any thoughts?
Alfred.NESWADBA
welcome @Anonymous!
Then most probably the current text-style you are using has already a fixed text size.
Start command _STYLE, select your style and look on the right side to the text height, if it's not 0 then change it to 0. Next time you start command _TEXT you will be asked for a height.
As long as there is a height (other than 0) defined, the text command automatically uses this value.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
IT WORKS! thank you so much for your fast response
