Simple Command Line Error
nt937HX
Observer Observer
nt937HX
Observer
Observer
I am new to scripting in AutoCAD but I am in need of a way to automate some processes.
I am trying to run this simple script:
         ; Test script
         _textscr
         Hello, AutoCAD!
Instead of displaying Hello, AutoCAD! I receive the below error.
I am sure this is a simple question but I appreciate your help.
Nathan
imadHabash
Hi and Welcome to AutoCAD Forum,
TEXTSCR (Command) Opens a text window that displays a history of prompts and command line entries for the current session. So it's normal that you have such an error with Hello command because there is NO hello command in AutoCAD .
BUT if your need is how scripting in AutoCAD then i suggest to follow this link that may help you .
Imad Habash
paullimapa
Script file basically contains a sequence of AutoCAD commands.
The above line is not a command as you can see from the response on the Text window
Now if you incorporate lisp functions then the following line will work when placed in the script file:
(alert "Hello, AutoCAD")
Paul Li
IT Specialist
@The Office
cadffm
and why the error appears for "Hello," and not for "Hello, Autocad!":
Because a commandname never include a blank, the blank will interpret as [Enter]
Sebastian
Kent1Cooper
(prompt "Hello, AutoCAD!")
Kent Cooper, AIA
