Signtaure to DWG
Signtaure to DWG
spufut
Signtaure to DWG
spufut
Hi ! I want to create my signature in Autocad. I tired to convert JPEG to  DXF then create a block, but I think the convertor took the line weight of my signature on paper and it is like contour without hatch inside (1st picture). The model i want is that my signature looks like a polyline(2nd picture). Do you have any idea how could I do it?
Michiel.Valcke
You can draw it? use the _Sketch command to have a more fluid pen-like motion for your polyline. Or you can insert a jpg/pdf version and draw on top of it.
pendean
Community Legend
Community Legend
Purchase a quality Raster-to-Vector converter to do that: or for free you can install the free-to-all-active-subscribers-of-autocad the RASTER DESIGN add-on then trace over your high-res image to create an autocad-objects copy of it.
Assuming you really and truly want your signature to go out to everyone on the planet when you ship it out of your office of course.
paullimapa
Since it’s now a pline in AutoCAD, why don’t you just use the Hatch command and select Solid pattern to fill in the gap?
Paul Li
IT Specialist
@The Office
