Show, in layer manager, only unused layers
Karol-Or
Karol-Or
I have Autocad 2014
I want the layer manager to show me only the unused or used layers
The layer filter doesn't have that option
pendean
Community Legend
Community Legend
Karol-Or
They're only general layer filters explanations, i didn't find the answer, how to show/hide used layers
Someone says there that even on version 2015 he doesn't find such a property filter
cadffm
Which Product(version)?
Only used Layer-filter is standard and should be visible on the left part of layerproperties-manager.
(also available to show the filter on the right in the layer list)
Upload a screenshot of your layerproperties-manager with both sections(Filters and Layerlist) visible.
How to use Layerfilters for on/off ->
Set the filter active and select all layers on the right
OR
Right click on the filter -> Select all
and then do what you want.
Sebastian
ВeekeeCZ
Focus on "Status" column. Search in HELP for more info.
Also might need toggle the indicator on.
Alfred.NESWADBA
you need to turn on SHOWLAYERUSAGE and then use this setting in the layermanager:
Take care ... sometimes the refresh button in the layer-manager (upper right) needs to be used to refresh the "unused layer" list.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
