Show command names on Modify section
1903040044
Observer Observer
1903040044
Observer
Observer
Hey! I attached 2 images below, image 1 is from the "Modify" section on my AutoCAD program, as you can observe only see the logo for each command can be seen. Image 2 if from a random YouTube tutorial where s/he has the logo along with the title of the command. How can I make the command names always show on the "Modify" section (or any other section) instead of having to hover every time to know what stands for what?
cadffm
you (and so many others too) posted just a snipped of the program window,
this way we can not see all needed information and we have to guess:
Your monitor is not wide enough to display all items in all panels of this tab with all information.
(or there is a problem with your resolution and AutoCAD thought there is not enough space)
Just for a test:
un-dock your LAYER panel from your tab, can you see the text in Modify panel now?
If it is not solved, please share a screenshot of your whole program window while start tab is active.
Sebastian
Observer
Observer
Thank you! It worked by dragging and moving the section on the right of the modify section. Now I can see everything. I guess it is the size of the screen.
