Link Dynamic Block Properties to table using field expression
jyothissurendran
jyothissurendran
I have a dynamic block, which has to be linked to a table to get X & Y coordinates. This we usually do using field expression by selecting object and position. Now the question is, is there any option available in same block if I wanted to get the coordinate of another object and link to the table ? eg: I have a rectangle and circle in block. Block base point is lower left corner of the rectangle and circle is in the middle of the rectangle. Once the block is inserted in the drawing I can link to the table using field expression by selecting insertion point. so that i will get the X & Y. but to get the X & Y value for circle any options are available ?
Jyothis Surendran
Autodesk Autocad 2014 & Inventor Professional Suite 2010
Windows 10
jyothissurendran
Jyothis Surendran
Windows 10
JCKRU47
You might get an answer here, but you would probably have better luck in the Dynamic Blocks Forum.
Dynamic Blocks Forum - Autodesk Community
jyothissurendran
I have posted there also.
Jyothis Surendran
Windows 10
JCKRU47
Roger that. Always good to cast a wide net for the best answers.
Jason.Piercey
Should be able to use a Point Parameter on the circle and then instruct the field to use the appropriate properties of the block
jyothissurendran
Thanks Jason. Its working.
Jyothis Surendran
Windows 10
