Shortest distance between multiple points with a parameter off how many points
Hey all,
I'm working on a project where i need to connect multiple points and calculate the shortest distance.
I have 29 points, who can only be connected with 8 points max and they have to reach a center point. So i have multiple strings.
Is there a command or lisp what will do this automatic instead of trying all possible possibilities?
Many thanks.
Grts,
Koen
3wood
Can you post an image to demonstrate? It is not clear why only 8 points out of 29 can be connected.
first thanks for the fast reply.
The reason only 8 points max can be connected is that this represents a windfarm. The strings are cables. Only 8 turbines can be added on the same cable.
Picture :  (not all points are being used )
Kent1Cooper
@Anonymous wrote:
... i need to connect multiple points and calculate the shortest distance.
I have a feeling any automated approach would have to try "all possible possibilities" in any case, and would just spare you the trouble of doing it yourself.  But it's a hugely complex problem.  >This thread< is not  the same problem, but related in looking for the shortest total distance to connect multiple points, as a "Steiner tree" using the "Fermat point."  Its connection nodes do not  always fall on  the points [only in certain geometric relationships], but mostly out in the area between them, which is why it's not the same as your problem, and because of the 120-degree-angle relationship that results in the minimum-total-length Steiner tree, it goes about it in a way that wouldn't serve your purposes.  But it might give you some idea of the level of complexity.  It has a pretty reliable solution for three points, and one that works for four only within certain limits, but the complexity gets much greater very quickly with added numbers of points.
But I notice that the "strings" in your image are not  all limited to 8 points from the common connection point.  Am I missing something?  And would you actually want to do it with all the points, with the limited number just being for illustration, or would the User always be selecting a limited number of them?
Kent Cooper, AIA
Hey Kent,
Thx for your reply. I understand this is a very complex problem, thats why i was hoping somebody already solved it.
To give some more information. Not all locations (points) are being used, some points are just points for other layouts. Thats why i looks like a string has more then 8 points connected but the polyline only has max 8 vertex.
Basicly i'm looking for something where i can selected the points i want to use, the center point, and set the max points in a string. This should then make the polylines with the shortest combined distance.
"I have a feeling any automated approach would have to try "all possible possibilities" in any case, and would just spare you the trouble of doing it yourself." => this is true but a computer would do it allot faster then me.
Grts,
Koen
