Hey all,
I'm working on a project where i need to connect multiple points and calculate the shortest distance.
I have 29 points, who can only be connected with 8 points max and they have to reach a center point. So i have multiple strings.
Is there a command or lisp what will do this automatic instead of trying all possible possibilities?
Many thanks.
Grts,
Koen
first thanks for the fast reply.
The reason only 8 points max can be connected is that this represents a windfarm. The strings are cables. Only 8 turbines can be added on the same cable.
Picture : (not all points are being used )
@Anonymous wrote:
... i need to connect multiple points and calculate the shortest distance.
I have a feeling any automated approach would have to try "all possible possibilities" in any case, and would just spare you the trouble of doing it yourself. But it's a hugely complex problem. >This thread< is not the same problem, but related in looking for the shortest total distance to connect multiple points, as a "Steiner tree" using the "Fermat point." Its connection nodes do not always fall on the points [only in certain geometric relationships], but mostly out in the area between them, which is why it's not the same as your problem, and because of the 120-degree-angle relationship that results in the minimum-total-length Steiner tree, it goes about it in a way that wouldn't serve your purposes. But it might give you some idea of the level of complexity. It has a pretty reliable solution for three points, and one that works for four only within certain limits, but the complexity gets much greater very quickly with added numbers of points.
But I notice that the "strings" in your image are not all limited to 8 points from the common connection point. Am I missing something? And would you actually want to do it with all the points, with the limited number just being for illustration, or would the User always be selecting a limited number of them?
Hey Kent,
Thx for your reply. I understand this is a very complex problem, thats why i was hoping somebody already solved it.
To give some more information. Not all locations (points) are being used, some points are just points for other layouts. Thats why i looks like a string has more then 8 points connected but the polyline only has max 8 vertex.
Basicly i'm looking for something where i can selected the points i want to use, the center point, and set the max points in a string. This should then make the polylines with the shortest combined distance.
"I have a feeling any automated approach would have to try "all possible possibilities" in any case, and would just spare you the trouble of doing it yourself." => this is true but a computer would do it allot faster then me.
Grts,
Koen
