Shortcuts vs Command Line Autofill
edwa8511NDC57
edwa8511NDC57
I have been using AutoCAD for a long time and have a bunch of customized shortcuts that I'm used to using.  I recently upgraded from 2022 to 2026, and my customized shortcuts got messed up.  I'm going through them to fix issues but found an oddity.
In AliasEdit I changed the shortcut for Copy to CC.
When I type CC into the Command Line, I get the system variable CCONSTRINTFORM.
I thought it might be AutoCompete messing me up.  I turned it off, but there was no change; still no COPY Command.  I also tried turning off AutoCorrect with no change either.
Any suggestions out there?
pendean
Community Legend
Community Legend
@edwa8511NDC57 Does restarting AutoCAD fix the issue?
sthompson1021
Did you remember to use the REINIT command after changing the alias?
edwa8511NDC57
After restarting the first time, some of the changes took effect.  I am seeming to have to make one correction to ALIASEDIT per restart now.  I can't explain it, but at least it works.
