Shortcuts/command conflict
- Mute
- Permalink
- Report
Hi there,
I have a shortcuts problem here. The command "rotate", the default shortcut is "RO", while it is not very convenient so I change it to "R" in the acad.pgp. (of course I also change the shortcut of 'redraw' to 'RD' in case some conflicts)
It worked fine for a moment, but recently every time I press "R", it always shows the command "recombine (join)" first. And even if I press "RO", it sometimes conflicts with the third command "round (fillet)". So now I have to type the entire "ROTATE" to initiate this function.
This is very annoying and I have checked the acad.pgp, there is no such thing as "recombine" or "round (fillet)". The function of "recombine" is just joining two polylines which I can simply press "J" and the function of "round (fillet)" is just the same as "fillet" which can be lead by pressing "F".
So I'm wondering if there are ways to avoid this from happening?
Thank you very much
