I still use a few keystroke shortcuts for some of my most commonly used commands. One that I'm having trouble working is the "D" keystroke. I've modified this command to be DDEDIT instead of the default and have never had an issue until I installed Autocad 2015. It says it's an unkown command but when I go to modify the acad.pgp file it shows correctly in there? Just out of curiousity I created a custom keystroke command called "DDD" and made it the same DDEDIT command and that one works but the "D" won't??
Use TEXTEDIT instead.
http://forums.autodesk.com/t5/autocad-2013-2014-2015/ddedit-unknown-command/m-p/4925920
I did modify the command to textedit replacing it with the reference to DDEDIT but it still won't accept the command? What's wierd is that it only happens with the shortcut "D". "ED" activates the command textedit and any new shorcut I create with the command being textedit works it just work the "D"? Any ideas?
@cberquist wrote:I did modify the command to textedit replacing it with the reference to DDEDIT but it still won't accept the command? What's wierd is that it only happens with the shortcut "D". "ED" activates the command textedit and any new shorcut I create with the command being textedit works it just work the "D"? Any ideas?
No other shortcut prior to that listing in the PGP tied to "D"? (not sure if your image in the whole list)
Did you REINIT the PGP file?
Do you have any LISP routine tied to "D"?
There was another reference in the .pgp file that I overlooked that still referenced DDEDIT. I modified it and now the command works!!! Thank you for your help!
You're welcome.
