Short cut keys & commands not working properly
I'm having a issue with using commands/hot keys/and editing text in place
I used to be able to highlight a selection/type a command (ex: CO)/ hit enter and it would just ask me to select a point to grab from.
Now for some reason I have to type the command in/ hit enter/ highlight the selection/ hit enter/ then select a point.
I also can't double click to edit any text or blocks in place or right click to change layer option (send layer to front or back). I can no longer us the delete key to erase. I have to type erase/hit enter/highlight area/and enter command.
Any idea what could be causing this?
imadHabash
it's obvious that your settings - some how - modified and change for a reason . please try to :
  • change PICKFIRST system variable = 1 .
  • make sure that DBLCLKEDIT system variable is ON .
  • from OPTIONS command >> User Preferences check your right click customization .
Imad Habash
Thanks!! The PICKFIRST variable was set to 0. No clue as to how it change but it works now
imadHabash
if you have used a certain outsource lisp or a plug-in , it may cause this issue . 😉
Imad Habash
