Find and replace only with command line NO LISP
Message 1 of 12
It is possible to find a text and replace ONLY with the command line or a script (.scr) ? No LISP or software
Replies (11)
Message 2 of 12
cadffm
Only with attribut value by -ATTEDIT
Sebastian
Message 3 of 12
the text is not in a block...I can't use this command
Message 4 of 12
cadffm
So, there is no solution for this goal inside of Autocad without any API (like lisp, .net) and without another program.
It is only available in some cases for attributes,
or via api
or outside AutoCAD
or with another program which can control the find dialog for you.
Sorry
Sebastian
Message 5 of 12
Kent1Cooper
Does that prohibition include "No FIND command"?  That isn't either AutoLisp nor external software, but a regular AutoCAD command, and will find and replace text content of all kinds, including in Attributes.  But it does  involve a dialog box, if that means it doesn't qualify for you as "ONLY with the command line."
Kent Cooper, AIA
Message 6 of 12
I can't use dialog box. I need to give all the command in the command line or in a script
Message 7 of 12
cadffm
"command line or in a script"
That statement sounds curious. If you had wrote "via Keys or in a script" - ok,
but why "command line or in a script"? Do you use another program to record your steps?
then the third part program pretty sure record your KEYBOARD-Input and you can control
dialogs with only-key input.
Sebastian
Message 8 of 12
no no just because I use VBA code to write in the command line on AUTOCAD Smiley Very Happy
Message 9 of 12
cadffm
If that was a joke, that was good!
And now start with real programming and do not spend more time for lazy cheap solutions.
For the next time maybe mention that one works by VBA,
because then maybe you would already have a (vba) solution.
Sebastian
Message 10 of 12
JTBWorld
You can do this directly in VBA.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Message 11 of 12
Shoud you post a example of code?
Message 12 of 12
JTBWorld
If you post in the VBA Forum you might get help for free or contact me directly if you want to outsource the programming.
Jimmy Bergmark
