SHIFT Ortho Toggle not working
sri.ravi36
Message 1 of 11
sri.ravi36
Shift Toggle in Ortho not working. Have tried TEMPOVERRIDES and CUI Ortho Toggle but of no use. Please help me ASAP. Thanks in advance
Replies (10)
Message 2 of 11
imadHabash
I suggest to reset your AutoCAD to default settings.>> Click <<
Imad Habash
Message 3 of 11
sri.ravi36
Have tried resetting and even reinstalled AutoCAD but still the problem continues.
Message 4 of 11
imadHabash
Ok.
Just a try ... Would you change your keyboard with any other one and see if any changes?
Imad Habash
Message 5 of 11
sri.ravi36
Tried with an external keyboard too. No issues with my keyboard. Still the problem exists.
Message 6 of 11
-didier-
Bonjour @sri.ravi36
Is there a "Function" Key on your keyboard ?
The F8 key works on other software ? In example on Excel try to run a macro pressing F8.
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Message 7 of 11
pendean
Community Legend
Community Legend
Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
HTH
Message 8 of 11
paullimapa
Try this test. Create a new Windows user account with local admin privileges. Sign into Windows using that new account then launch AutoCAD and see if it works
Paul Li
IT Specialist
@The Office
Message 9 of 11
psitrop
Good afternoon. I have the same problem. The shift has stopped working. It happened a couple of days ago. I tried all possible options. It doesn't work anyway.
Message 10 of 11
psitrop
Hi. I still managed to solve this problem. Having tried everything, I already wanted to reinstall Windows. But at the last moment I decided to remove the driver of my nvidia graphics card and restart the computer. Now it's working again. maybe it will be useful to someone.
Message 11 of 11
sri.ravi36
Thanks all for your replies. I have solved the issue. The problem was with the latest windows 11 update. I have uninstalled the last update from my laptop and my CAD worked fine after uninstallation. Try this out if nothing works. Go to Settings--->Windows Update--->Uninstall updates--->Uninstall the last update from which the issue started. That's it.
