Shift button to cancel the selection of unnecessary objects
yury.starkov
Message 1 of 9
yury.starkov
Earlier, when the shift was clamped, I canceled unnecessary selected objects. Right now this is not happening, the AutoCAD version is 2022. I tried to turn on/off PICKADD - there are no changes. In 2020, everything works fine.
The second question is - are you all foreigners, or is the forum here only in English?
Accepted solutions (3)
Replies (8)
Message 2 of 9
Alfred.NESWADBA
do I understand the question correct (or can you try the same workflow in a new drawing):
  • You have 2 lines in modelspace
  • You have selected both (property window shows 2 lines selected)
  • Now you press and hold <SHIFT> and click onto one of the two lines
...what happens now exactly, also in the command-line?
Well, what does "foreign" mean in an international forum? The users here are placed all around the world.
For some languages there exist special forums as you can find here:
https://forums.autodesk.com/ and click onto "International" and select the language you prefer to use...
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 9
imadHabash
It's usually happened when there is another software is existing in your PC like Raster Design .. I suggest to follow this link that may help . >> Click <<
Imad Habash
Message 4 of 9
yury.starkov
Yes. Raster design is installed. How to fix the error?
Message 5 of 9
yury.starkov
Yes, the raster design is installed. how to fix the error?
Message 6 of 9
yury.starkov
Message 7 of 9
imadHabash
Great .. You have to change the setting as mentioned in my previous message .
Imad Habash
Message 8 of 9
yury.starkov
Thank you very much. I tried the second variation - everything worked out!!!
Message 9 of 9
yury.starkov
and nothing happened at all. the selection frame did not appear. I did as in the post well - everything worked. Thank you for answering, too!
