Sheet Sets. Subset Custom Properties
oswaldodcb
Advisor Advisor
Message 1 of 8
oswaldodcb
Hello to the community,
In this opportunity I write because I have a question about whether it is possible to add Sheet Custom Properties by Subset, because I know that I can place per page and the whole sheet set,
I need to add properties that I can edit by subset and not the complete sheet set,
I hope I have explained well and I am attentive to your comments,
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
Replies (7)
Message 2 of 8
rkmcswain
AFAIK - custom properties can only apply to a sheet set, or a sheet.
Message 3 of 8
oswaldodcb
Thanks for your answer,
Do you know of any way to do it? a lisp or some free application that serves for that purpose?
Oswaldo Caballero
LinkedIn
Message 4 of 8
rkmcswain
Couldn't you make a sheet set custom property and then just use it where ever needed?
Or do you need to use this property on ALL sheets, but have a different value per subset?
If the latter, then maybe JTB World SSMPROPEDITOR could help you edit multiple properties at once.
http://jtbworld.com/ssmpropeditor
Message 5 of 8
oswaldodcb
What I need to do is the second one you mention, and the application you mention would serve me a lot, download it to prove it,
Although it would be good to add that function to the options in the Sheet Set Manager,
Thanks for your help,
Oswaldo Caballero
LinkedIn
Message 6 of 8
rkmcswain
Unfortunately in the past 13 years since SSM was introduced in AutoCAD, very few enhancements/improvements to SSM have been added.
Message 7 of 8
DJGinAZ
@rkmcswain wrote:
Unfortunately in the past 13 years 19 years now since SSM was introduced in AutoCAD, very few enhancements/improvements to SSM have been added.
I was hoping something had changed now that it's been functional in Docs for some time. I guess there's still no movement on this. Yay...
Message 8 of 8
gkleinebecker
Observer
Observer
This isn't ideal in my case. I use subsets to define different submittal packages. Each package will have a different number of total sheets. If I could have a subset custom property for total sheets then the field  in the template could always read this. As it is now I'd have to make a new sheet set custom property them make sure to change the field on every sheet (or at least the very first one) to reference the new field for the new subset. Subset custom properties would make updating old drawings and creating new subsets from our template a million times easier. (also I saw a blog tutorial showing it as an option on some version of CAD that I couldn't verify but they were clearly on windows 7 or 8. If it existed at one point why take it out?)
