AutoCAD Forum
sheet set managet data types not colpmete
0 REPLIES 0
Message 1 of 1
279 Views, 0 Replies
Hi All,
I try to insert sheet list table  , but when I go to "Table Data " Tab and click add button to add new data , then try to select the data type i want from the drop down menu (as in the attached photo) I don't find the desired value (i.e. Drawing file name , system variables etc )
I only get the values as you see in the photo , which are very limited to what we get in case of data  fields ...should they be tha same ?
help please
0 REPLIES 0
AutoCAD Inside the Factory
