08:37 AM
- Mute
- Permalink
- Report
I'm new to SSM and have an existing project that has a large number of sheets already set up.
Each sheet had its own revision number controlled by the SSM.
I can only change the revision numbers individually from the sheet set manager.
If I wanted to do a global change to the revision numbers and change them all to the same revision number, I assume that I can only do this one at a time in the SSM. Or is there some way to apply this as a global change in one shot? I'd have to do this without breaking the original links.
I can't see any way of doing this but as I'm new to SSM I wanted to check that I've understood things right.
