Sheet Set Field Value: Delete Saved View Name Prefix
Jake_PCH
Jake_PCH
I am using a prefix numbering system to organize my saved view names but I do not want that prefix to show in the view name within the placed view block, as indicated below.
Is it possible to manipulate the field value shown below to remove the first 4 characters?
Ie. How can the field expression given be embedded within in a larger expression that removes the 4 characters?
Brock_Olly
Use a dieselexpression, a piece of code to remove the first 4 characters from the string.
Wrap your field with $(substr, ... , 5, 256) I think the following should work:
$(substr, $(eval, VIEWTITLE>), 5, 256)
Jake_PCH
Hi Brock, that's exactly what I was thinking along the lines of - thank you for sharing your Diesel knowledge.
However, this appears to edit the Temporary value of the Field Placeholder Type and subsequently breaks the link as shown below;
Any ideas...?
Brock_Olly
My diesel 'knowledge' is very limited, but you should be able to wrap your previous expression with the one I posted.
%<\AcSm ?View.Title \f "%tc1" \href "?href###0">%
becomes
$(substr, $(\AcSm ?View.Title \f "%tc1" \href "?href###0"), 5, 256)
Jake_PCH
I tried that and it gave the same result.
I believe the problem lies in the distinction between Attribute Definition (Associated with Block definition) and Attribute Value (Associated with Block Insert), so my presumption is that it would require a string that is able to 'Get' the Attribute value prior to applying the character edit.  The question is, is that possible...?
Brock_Olly
Maybe try wrapping it with %<..>% it will treat it as a field expression
$(substr, %<\AcSm ?View.Title \f "%tc1" \href "?href###0">%, 5, 256)
I cannot try the code because I don't have a sheetview setup like you do..
Though if this doesn't work it might be impossible to do with diesel expressions since it looks like diesel doesn't have access to the SSM properties, only system variables.
Jake_PCH
No Luck unfortunately.
I have attached the SSM & Corresponding layout file for your reference.
