SHEET SET DUPLICATE COLUMNS PROBLEM
fernandoosorio01
fernandoosorio01
Hey someone know how to fix this problem when I try to create a sheet set table
the sheet title and sheet number brings the same information.
pendean
Community Legend
Community Legend
Do you have the same exact information in both sections by chance? Check your RENAME AND RENUMBER SHEET pop-up to confirm, they are two separate entry boxes
user181
When you try to insert it make sure the data type is set for each column to the correct data type
fernandoosorio01
yes is weird I dont know why this happening is the first time sheet set 2.jpgsheet set 3.jpghis happen
