Hi @natasha.l
I am not sure I following you. I do understand the use of fields and attributes, which is how we have set up our drawing title block to work.
Which is then populated by data we have specified for each drawing in the SSM, such as drawings titles, numbers, and revision details.
We are wanting to use the auto cad feature that allows you to insert a sheet list table into a cover-sheet drawing, that will be populated with the data from the SSM, with all the sheets and current revision for each project.
I have been able to get that working fine, apart from the 2 problems I have posted here and they are:
1. At the moment when I go to insert the sheet list table using the SSM it brings a dialog box up with the options to set up the table as you require. Here is how it appears by default:
So that would give a table with just the Sheet title and Sheet number.
I need to have Sheet title, Drawing number (for us is project number and sheet number) and current revision.
Now I know how to get that information in there, using the add, and selecting data type and specifying the heading text. What I would like to know, but I have heard that it may not be possible, is to be able to tell autocad what I want the default option to be, the image that I attached to the previous post is the same setup that we will be using on all projects. This is all for the purpose of saving time, as we are doing 450+ projects per year.
2. In order to avoid the potential for the drawing to be sent out with incorrect data in the table, I would like it to update automatically when saved. Which you said should be able to set with DXEVAL system variable, which is currently set to update upon saving and opening.
For other data extraction tables we currently use, this variable updates this works fine, and they update when the drawing is saved or opened. This does not happen for the sheet list table.
Hopefully that has clarified my query better.
And thanks again for your continued help with this.
Kind Regards
Brayden
