since i've started running autocad 2025 (and advance steel) the shared views no longer seems to work.
"unable to finish publishing shared view"
anyone else experiencing the same issues?
@paulcNDXJR
Welcome to the forum, Paul. Let me get the obvious question out of the way... do you have a good stable internet connection?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
@paulcNDXJR wrote:since i've started running autocad 2025 (and advance steel) the shared views no longer seems to work.
Using only plain AutoCAD (topic of this forum), SharedViews with your file fail for me in AutoCAD 2023-24-25, same as you noted in your post.
SharedViews seems to be working just fine with one of my own non-AS test file in all three software in a quick test right afterwards. Which may mean nothing or something.
if you tried other files with the same results... Here are ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
@paulcNDXJR Hello, do you still need help with this question?
Chris Benner
