Shaded visual style enabled in Layout mode
momacoo
momacoo
I am working in Layout mode and it seems Shaded visual style is enabled, this condition causes that line weights are plotted wrong. I tryed to change to Wireframe style but AutoCAD shows the message:
Unknown command "2DWIREFRAME".
Please notice that, I am NOT working with Viewports. I am using Base View functions.
[This post has been edited for clarity by cheryl.buck]
cheryl.buck
Autodesk Support
Autodesk Support
Hi @momacoo,
Thank you for posting. It looks like you are working in AutoCAD Mechanical.  Welcome to the Community!
The Visual Styles panel under the View tab only applies to Model space and Viewports. Viewbase view visual styles are available in the Drawing Views Editor tab:
  1. Select the viewbase view.
  2. In the Active Layout tab, select the Edit View button from the Edit panel.
  3. When the Drawing Views Editor tab opens, click the view in the Appearance panel.
  4. The view style can be selected from those available in the list.
Steps 1-2
Steps 3-4
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
momacoo
Thank you very much,
But it didn't work 😞 , I've tryed by selecting each view style in the list, and it results the same way
The version I am workign with, is AutoCAD 2018.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @momacoo,
I am sorry to hear that, 2018 also works for me, so it might be a damaged install or user profile. You could try a reset to defaults, repair, and/or reinstall.
All the best,
Cheryl Buck
momacoo
Hi, @cheryl.buck
I reseted and then reinstalled AutoCAD, but did'n work either
I Attach my file, probably I am doing something wrong
Thank you very much
cadffm
DELETE
Sorry, wrong thread
Sebastian
