- Mute
- Permalink
- Report
Could someone please advise on the best way to set & maintain viewport layer overrides for XREF layers in a template?
By default our template does not have any XREFs attached but we will, in 90% of projects, be adding XREFs from variable locations internally that are given the same XREF names in the drawing (e.g. source filneame is different but XREFs are given constant names "X Layout", "X Design" etc). We want to be be able to define the viewport layer overrides (freezwe\thaw, colour, lineweight) either in the template without the XREFs (or dummy equivalents) already attached or via applied fater the XREFs are attached via a very quick process (e.g. Layer States??).
What is the best way to achive this outcome?
